pb racer 6.2 avec wine sous linux (mandriva 2008.1 spring)
Message par joedu12 le Jeu 14 Aoû 2008 - 5:30
Bonjour, j ai telecharger la derniere vertion de racer pour win qui est sensé marcher sous linux avec wine 1.1.2 Smile
sauf que ben il se lance pas j ai essaille en konsole cd le /le/repertoire/de/racer/ et j ai tape wine racer.exe mais sans succses.
Sa m' etonnerais que sa vienne de wine puisque je fais tourner live for speed a merveille.
J ai la derniere vertion de racer linux 0.5.4beta1 mais bon compare a la 6.2 de win Neutral
Voila se que sa ma donne en demarant racer en konsole
wine racer.exe
err:winedevice:ServiceMain driver L"prodrv06" failed to load
wine client error:25: write: Mauvais descripteur de fichier
err:ntdll:RtlpWaitForCriticalSection section 0x7efecd40 "exception.c: vectored_handlers_section" wait timed out in thread 0022, blocked by 0025, retrying (60 sec)
wine: Call from 0x7ee19870 to unimplemented function ntoskrnl.exe.KeInitializeEvent, aborting
wine: Unimplemented function ntoskrnl.exe.KeInitializeEvent called at address 0x7ee19870 (thread 002a), starting debugger...
Unhandled exception: unimplemented function ntoskrnl.exe.KeInitializeEvent called in 32-bit code (0x7ee198f2).
Register dump:
 CS:0073 SS:007b DS:007b ES:007b FS:0033 GS:003b
 EIP:7ee198f2 ESP:7eb42840 EBP:7eb428a4 EFLAGS:00200212(  - 00      - -IA1)
 EAX:7ee03689 EBX:7ee988c0 ECX:00000000 EDX:00000000
 ESI:00000000 EDI:00000000
Stack dump:
0x7eb42840:  7eb428cc 00000008 0000003c 00000000
0x7eb42850:  80000100 00000001 00000000 7ee19870
0x7eb42860:  00000002 7ed0f9c0 7ed128b5 004509b8
0x7eb42870:  00000020 00000000 00000000 00000000
0x7eb42880:  00000000 00000000 00000000 7ed19e90
0x7eb42890:  7eb42924 7eb42914 7eb428e8 7ed0f7cc
Backtrace:
=>1 0x7ee198f2 RaiseException+0x82() in kernel32 (0x7eb428a4)
  2 0x7ed0f965 in ntoskrnl (+0xf965) (0x7eb428d4)
  3 0x7ed095f8 in ntoskrnl (+0x95f8) (0x7ed0f500)
  4 0x7ce85356 (0x57e58955)
  5 0x00000000 (0x00000000)
0x7ee198f2 RaiseException+0x82 in kernel32: movl        0xfffffffc(%ebp),%ebx
Modules:
Module  Address                Debug info      Name (30 modules)
PE        450000-  4512e0      Deferred        sfhlp01.sys
ELF    7bf00000-7bf03000      Deferred        <wine-loader>
ELF    7e991000-7e9a6000      Deferred        hal<elf>
  \-PE  7e9a0000-7e9a6000      \              hal
ELF    7e9c4000-7ea33000      Deferred        msvcrt<elf>
  \-PE  7e9d0000-7ea33000      \              msvcrt
ELF    7eb44000-7eb57000      Deferred        libresolv.so.2
ELF    7eb57000-7eb77000      Deferred        iphlpapi<elf>
  \-PE  7eb60000-7eb77000      \              iphlpapi
ELF    7eb77000-7ebdf000      Deferred        rpcrt4<elf>
  \-PE  7eb80000-7ebdf000      \              rpcrt4
ELF    7ecf0000-7ed28000      Export          ntoskrnl<elf>
  \-PE  7ed00000-7ed28000      \              ntoskrnl
ELF    7ed28000-7ed7e000      Deferred        advapi32<elf>
  \-PE  7ed30000-7ed7e000      \              advapi32
ELF    7ed7e000-7ed89000      Deferred        libnss_files.so.2
ELF    7ed96000-7ed9a000      Deferred        iso8859-15.so
ELF    7edd7000-7ef15000      Export          kernel32<elf>
  \-PE  7edf0000-7ef15000      \              kernel32
ELF    7ef15000-7ef3a000      Deferred        libm.so.6
ELF    7ef3a000-7ef3d000      Deferred        iso8859-1.so
ELF    7ef3d000-7ef51000      Deferred        winedevice<elf>
  \-PE  7ef40000-7ef51000      \              winedevice
ELF    7ef52000-7f000000      Deferred        ntdll<elf>
  \-PE  7ef60000-7f000000      \              ntdll
ELF    b7c88000-b7c8c000      Deferred        libdl.so.2
ELF    b7c8c000-b7dd0000      Deferred        libc.so.6
ELF    b7dd0000-b7de7000      Deferred        libpthread.so.0
ELF    b7de7000-b7f1e000      Deferred        libwine.so.1
ELF    b7f37000-b7f53000      Deferred        ld-linux.so.2
Threads:
process  tid      prio (all id:s are in hex)
00000008
        00000009    0
0000000a
        0000000b    0
0000000c
        00000029    0
        00000024    0
        00000019    0
        00000018    0
        00000013    0
        00000012    0
        0000000e    0
        0000000d    0
0000000f
        00000014    0
        00000011    0
        00000010    0
00000015
        0000001b    0
        0000001a    0
        00000017    0
        00000016    0
00000021
        00000023    0
        00000022    0
00000026 (D) C:\windows\system32\winedevice.exe
        0000002a    0 <==
        00000028    0
        00000027    0
Backtrace:
wine: Call from 0x7ee19870 to unimplemented function ntoskrnl.exe.KeInitializeInterrupt, aborting
wine: Call from 0x7ee19870 to unimplemented function ntoskrnl.exe.KeInitializeMutant, aborting
fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.VC80.CRT"
err:module:import_dll Library MSVCR80.dll (which is needed by L"D:\\T\00e9l\00e9chargement\\racer\\racer.exe") not found
err:module:LdrInitializeThunk Main exe initialization for L"D:\\T\00e9l\00e9chargement\\racer\\racer.exe" failed, status c0000135
Quel qu 'un pour m aider ? Suspect
joedu12
Nombre de messages : 20
Re: pb racer 6.2 avec wine sous linux (mandriva 2008.1 spring)
Message par Poulpha Racing le Jeu 14 Aoû 2008 - 7:54
alors sur Wine AppDB un utilisateur a fait le test avec Racer v.0.5.3 et d'après lui tout fonctionne bien :
http://appdb.winehq.org/objectManager.php?sClass=version&iId=9837
Mais aucune version plus récente n'a été testée, et celle-ci est plus ancienne que celle que tu as sur Linux.
Enfin je n'ai pas encore testé Racer sur mon Ubuntu (je ne sais pas si ta version 0.5.4 est aussi avancée que la 0.5.4 sur Windows) mais d'après de nombreux utilisateurs de Racer, la meilleure version est entre la 0.5.3 et la 0.5.7.
Les v.0.6.x entraînent des low fps et n'apportent pas énormément de corrections de bug.
Message par joedu12 le Jeu 14 Aoû 2008 - 8:22
ok merci
joedu12
